Access is denied??
mrapoc
Ok, having setup my raid0 at last, I have my "old" 200gb in an external enclosure running sata into my pc as a backup. I go to copy my files across from my "Sam" folder in "E:\Documents and Settings" to copy music, downloads and work etc. over and I get the message:
E:\Documents and settings\Sam is not accessible.
Access is denied
[OK]
So, whats going on?
Thanks
So, whats going on?
Thanks
you need to set the NTFS permissions and ownership to your UserID or User Group
Properties >> Security >> Advanced >> Pwnership
Change Ownership and set the tick box at the bottom to replace the child object permissions :D
Pwn ur files so the F/s will allow u access (u need to be an administrator)
Similar situations to this, like putting an old boot drive with a busted windows on it as a slave, won`t let u access it even as an admin.
Hope it works out in this case.
name='mrapoc' said:
Ahh thanks man, had to log in as admin in safe mode and its all done now...reppers are in order :)
why thanks you .. just for future reference you can log-in as Admin on startup @ the welcome screen/ login screen (u may have to log out for auto log-in systems) by pressing the Ctrl-Atl-Del key combination twice in succession
