Hi all,
Took a browse around the forums and web and found some useful infos. However, I'm keen to now get some opinions on the setup I've put together for myself. Note that this is going to start off as a single loop system, but will undoubtedly be upgraded to include a second loop in the near future:
Thanks all.
- 1x Swiftech MCP355 pump (weighing up against the MCP655)
- 1x XSPC Dual 5.25" Bay Reservoir (should the MCP355 be chosen)
- 1x Black Ice GTX Gen Two Xtreme 360 Radiator
- 1x Danger Den MC-TDX Block (or Swiftech APOGEE XT REV 2; whichever is less restrictive, bearing in mind the eventual addition of a GPU block. The EK-Supreme HF High Flow block was also recommended to me)
- 6x PrimoFlex Pro LRT UV Blue Tubing -1/2" (6 feet total length)
- 6x Danger Den FB (Fat Boy) G 1/4 Fittings - 1/2"
- 6x Lamptron Elite Aluminum Reusable 1/2" Clamps
- 1x IandH Silver KillCoil
Thanks all.
