My NEW Liquid Cooled Rig
Hi, I'm ACE384.
Old UGLY Desktop pics were taken down, so this is just for my NEW rig now.
This is mainly a vanity gaming rig, I built it for show. having alot of high end components is a bonus. At one point i add some new components to it after it was mostly done, a temperature sensor attached to my graphics card, leaked onto my motherboard, luckily the Graphics card wasn't damaged but the motherboard was. When i got the new motherboard in I decided not to put the motherboard water blocks on it.
FINAL STATS:
case- XSPC H1v2 (discontinued unfortunatly)
Bay-Left-
Akasa Lokstor M51 (SSD&HD Hot swap + 2 USB 3.0)
LG Blueray Writer
Akust 5.25" bay drawer
(Empty)
Bay-Right-
(Empty)
Monsoon M2-D5P-RD Dual bay Res and Swiftech MCP655-PWM Pump
Lian Li Bay mount with Thermal-Star Digital Gauge
Cooling Loop Components-
Koolance QD3 Quick Disconnects.
Monsoon Free Center Compression Fitting - 7/16"ID x 5/8"OD - Single Black Chrome.
PrimoChill PrimoFlex Advanced LRT Tubing 7/16"ID x 5/8".
Koolance LIQ-705 Liquid.
Radiator-XSPC AX360 Triple Radiator
Fans-9 Corsair high static pressure, high performance fans. 8 Corsair high air flow, quiet edition.
Power Supply-Corsair AX1200 power supply (been considering getting another 7990), added the individual sleeved white cables.
Controller-Corsair LINK, controlles 13 fans, 3 LED light bars, Swiftech Pump in res., and reads the koolance temp sensor attached to Graphics card.
Motherboard-Rampage IV Gene (did have a Rampage IV Extreme, but i thought it had alot of waisted space on it) (besides the Gene can support 2 7990's just fine).
CPU-I7-3960x 3.3GHz (not OC'd)
Ram-32GB of RAM, 4x8GB Corsair Dominator Platinum 1866MHz Quad channel Ram (not OC'd) (I got the ram addon light bar, but im not sure if I want to put it on yet).
Video Card-PowerColor AX7990 6GBD5-2DHJ Radeon HD 7990 Video Card with EK-FC7990 Water Block (not OC'd).
Network card-Killer 2100 Network Card (got it to mostly just fill up space).
Sound card-Creative Sound Blaster Z SB1500 sound card (also mostly got to fill up space).
OS Hard drive-120GB Force Series GT SSD SATA 3 (Plan to get a 240GB Neutron Series GTX SSD soon) (OS drive of course)
Other Hard Drive-2TB Western Digital Black SATA 3
I found no need to overclock. But if I do i'll have plenty to play with.
Idle Temp.
CPU-35°C
GPU-34°C
Liquid-30°C
Under Load running Eyefinity on Ultra graphics
CPU-40°C
GPU-40°C
Liquid-32°C
------The Big Boy Build------
MONSTER CASE!!! XSPC H1 v2... Discontinued unfortunatly.
Using a Corsair Link to controlle all 9 of the radiator fans ,4 case fans, Pump, and the LED kit in the skylight.
Idles at 30c Maxes at 35c
Very handy for storing tools and thumb drives
Cycles through the LED Lights thanks to the Corsair LINK
Eyefinity 5760x1080 Gaming!!!
------Did some Cable Cleaning------
I tried to take this pic a few times and none of the times made it look as good as it does in person.
Zipties work great, but somtimes some electrical tape will do. Keep is in one place and tidy
Took out a fan that was chirping. plan to replace. Sorry for the LED glare.
I like the look of just 2 black wires stretched accross. One powering all the fans and the other for the Corsair Link Cable.
Yes. Zipties are keeping the second set of fans on... Finding the right screws for this setup is hard.
The main motherboard cables are the worst to tidy up.
Hi, I'm ACE384.
FINAL STATS:
Bay-Left-
LG Blueray Writer
(Empty)
Bay-Right-
(Empty)
Idle Temp.
CPU-35°C
GPU-34°C
Liquid-30°C
CPU-40°C
GPU-40°C
Liquid-32°C
