i just wanted to see what you guys thought of my water cooling parts list before i got and make it final.
CPU Block: - EK Supreme HF Easy Mount CPU Waterblock
Radiator: - Hardware Labs Black Ice® GT Xtreme 360mm
Reservoir: - Danger Den RAD Reservoir (wont be fan mounted but like the look of it)
Fill port: - Bitspower 1/4" Case Top Water Fill Set / Fill Port Matt Black
Drain Port: - Bitspower 1/4" Case Top Water Fill Set / Fill Port Matt Black
Fittings: - Bitspower 1/4" Thread Compression Fitting for 1/2" ID - 3/4" OD Tubing Matt Black
Bitspower 1/4" Thread 90 Degree Rotary Compression Fitting for 1/2" ID - 3/4" OD Tubing Matt Black
Bitspower 1/4" Thread 45 Degree Rotary Compression Fitting for 1/2" ID - 3/4" OD Tubing Matt Black
Tubing: - Masterkleer 1/2" ID - 3/4" OD (13-19mm) Flexible Tubing : White / UV Blue
Pump: - unsure if i should use a single/twin Laing DDC (18w version) or Laing D5
i wont be adding the gpu to the loop until the new series of cards come out then ill be looking at a crossfire or sli setup so i guess they are going to need another 360mm rad
