9500GT upgrade
Hi, i just upgraded to a 9500gt 1 gig version, all working fine just intrigued what the lead in the box is for? its got a 2 pin connector that goes on the board with a +/- wires coming off it? any ideas and do i need it? cheers
The cable links the SPDIF header on the motherboard to the SPDIF input on the graphics card, allowing you to run sound through the HDMI port.
You don't need to connect it, unless you want to run sound over HDMI.
dya know i've been rackin my brains for days trying to work out why i can't get audio over hdmi then remembered this post :rolleyes: now what did i do with that cable ? :sleep:
