900D Water Cooled GTX 780 TI Classified SLI
I don't know what to say for this rig...except simply excellent...
that's small word for this...
Shape of loop is excellent... OK I'm against memory cooling because don't need but look fantastic and who have money, why not.
I plan water cooling but much smaller, because it's my first and I read few days about everything and compare and I decide to go with XSPC Photon 170 D5 pump and res together, AX240mm for CPU and AX120mm for GPU, compression fittings XSPC of Koolance, not fat tubes, middle, block probably CPU-380SI if I find, I will find, only must search more and few things for visual look as Aluminium ring for D5 pump, white leds, drain valve, that's it. I think XSPC Photon 170 combo is newer than Dual Bay res and maybe look nicer...
