shambles1980
Ok..
So im sitting here waiting for the water block to arrive when i decide to get a house fan out and point it at the gpu and see whats what with it..
Turns out i was never getting more than 1.8v
and I was hitting the TDP limit causing throtteling as i tried to push it up.
SOO i went looking for a bios. and couldnt find one and eventually decided i had to edit my own.
After i did that flashed the thing then sat here hoping the pc would actually boot...
I went back to testing my card.
Seems i can get it to about 1.3Ghz at 1.21v which is not at all shabby.
I did try it at 1.38 but then i got TDR's and driver crashes. And i did not want to push my luck with my make shift cooling solution. So i called it a day.
here is a nice pic.
(i ran fire strike. got 9970)
and i decided to compare it with a similar scoring 780ti
http://www.3dmark.com/compare/fs/5443547/fs/5436004
i was quite suprized how close the scores were after seeing how badly my i5 scored compared to an i7..
Really looking forward to the water block arriving now.
i can probably tweak the ram a bit more then, but without any temp monitors for those i really dont want to take the pee..
Im pretty sure that this is a reasonably decent 780.
I may or may not update this thread after the block arrives..
I do assume my OC will be about the same given that i was hit with TDR's and not a thermal throttle
so all it really should do is drop the temps down nicely so i can concentrate on the ram..
Any kind of luck i can hit 10k points woot lol.
"its really for gaming so im not going to go 1.3v or something stupid just to achive that"
here is a nice pic.
