900d question
SparkleDJackson
Hey guys. I'm planning on getting the 900d but I can't remember seeing anywhere how much clearance there was in the roof for a push pull 60mm rad the 810 has zero clearance lol between the fans and the top of the board. My wire are TIGHT at the min I'm hoping I could slacking them a little in the future to remove a little strain. Has anyone seen any details
iirc it ttl said push-pull with a 60mm rad does fit when you got a motherboard without big headsinks up there
Is it possible to mount fans(8)
with the HDD cages installed
in the bottom of the 900D?
