shambles1980
Ok.
so my haf 922 case is really to small. I have a 60mm rad in the top with 0 fans in the case and it BEARLY clears the memory I had to mount the fans outside the case with fan grills (kinda looks ok because the HAF has a high part at the front any way)
Basically though the case is to small for water cooling properly. i did manage to mount a 60mm 240 at the front as well which means that my water cooling for the cpu and gpu is "adequate"
What i actually need however.
Is a case where i can mount atleast a 240 60mm in the top in push pull no problems.
Then a 240 60mm at the front in push pull "no problems"
And preferably an extra section at the bottom for the psu, and 2 more 240 60 rads (or larger) (they do not have to be push pull but would be nice)
the 900d seems to be able to do that with ease. But its pretty damn expensive.
I looked at the 750d and i dont think i could use that one.
The 800d i cant tell but i do think its a bit smaller.
So are there any other alternataves?
I use a 2 bay res so needs a MINIMUM of 3 5.2 bays.
I do use mechanical drives still so a movable 3.5 rack "4 drives" would be wanted.
and i have an ssd so i wouldnt mind if that gets mounted at the back of the motherboard or where ever.
What are my choices?
