8800gtx/s 3dm06 score and overclock
BigD
I would like to compare your cards at cpu speeds and your overclocks!
there will be two main categories with two sub categories,
8800GTX
Intel
AMD
8800GTS
Intel
AMD
1. BigD opty @ 3ghz 8800gts 645/2000- 10452
and your score, cpu and gpu clock speed will go into there
and to start it off
me:
AMD opty 170 @ 3ghz
8800gts @ 645core 2000mem
http://service.futuremark.com/compare?3dm06=1466690
Checkout the benchmarking part of the forum, there`s a number of peoples in there that will have the results u`r after.
To be fair, having the regulars scores and rigs in the opening post of the benchmarking thread is a great idea.
Saves flicking through all the screenies.
just what i was thinking, should this be moved from the grfx card section to the benchmark?
Nice score, BigD:cool: , but you got that 8800GTS clocked pretty high... tell me that's with water or at least an aftermarket HSF.
I'd say just post the score in the benchmark area and then delete this thread (I think you can do that).
For as long as this thread is up, I can vent another frustration. Futuremark has a comparison program, but you can't tell it if you're using a single video card or SLI/Crossfire... wish they'd make that an option, then I could see how well I'm really doing. (my C2D @ 3.6GHz/single 8800GTS @ 600/926(1852)/ AW9D-975X = 10150 on 3dmark06)
nah its on air... and i havnt seen it get any hotter than 75*C
yes i have that same frustration with sli/single on orb
i noticed that my score was from a 1280x768 resolution instead of a 1280x1024 so i ran a new test on my other monitor withhigher clocks and my score still dropped 100 points
ill make a new thread in benchmarks
