8800gt g92 how hot ??
WelshD1K
well my 8800gt g92 gainward single slot gpu is getting silly hot :S idles at 55 and goes to 85-90 playing a simple game like cs:s and its still at stock speeds :S
is this normal my old palit8800gt g92 cheap and nasty card never went over 60
that means the fan speed is always the same.. so if the fan always spins at like 45% of course it will get hot.. stick it back on dynamic so the fan speed will increase when it gets hot.
I had to flash mine (evga) so the dynamic speed would actually work...not sure if u would need to. google around
I have 2 x 8800 GT from sparkle and had same problem , idle temp 68-73C and when gaming 90-98C (stock setings not clocked), freaking hot and loud , last week i have buyed 2 x Zalman VF1000-LED VGA Cooler, a bit expensive but what can i say , idle temp are 40-45C and when gaming max 60C-62C (even when clocked core clock 647 MHz and mem to 960MHz(eff 1920MHz)it went to 69C @room temp about 20C). about sound ? dont hear them at all more noise i get from case cooler (with is very quiet).but i`m thinking about new rig now, i will start to build next month and i`m 100% sure that i will put watercooling for cpu chipset and VGA card. if you want to stay with this card i think paying 27 pund for extra cooling will be good idea ,but its up to you.
