800d case build log recon 50 cal
GROUCHY
Hello there all im kinda new to this dermal drilling rivets vinyl cutting on a case but i thought to my self the 800D got things i don't need IE hdd bay that bay under the middle part so done a 240 rad mod there but here is some pics where im kinda at it is a really is a slow build just doing it by my self and not got the experience im kinda failing lol
but ill post the pics as where im at right now thanks guys for letting me share this :)
carbon vinyl blue and black pilot switches and cover for top of the 800D
carboning the mobo and pci e slot tray
DREMLING THE 5 INCH BAY UNDER PLASTIC COVERS TO MOUNT 6 INCH BAYS IN and from 5 front bays now got 6 bays
a few comments i got ATM
Sorting out the top 3 fan and rad holes
so yeah alot more to do but i get there and i keep you guys updated
Mate first and only time - one post at a time OR use the edit button.
Ive merged them this once. If it happens again youll get your chocolate starfish stretched by the mods.
my bad tom sorry bud but don't need to say your gonna stretch my chocolate starfish that's kinda of a insult i didn't know so u know no need to come at me like that but fair enough i keep it all in 1 post sorry again tom:confused:
I fooking hate the case with a passion, still think the same I did when I reviewed it.
Youve a lot of work to do getting things looking good too.
yeah its a no a bad case it just huge and is easy to work with the 5.2 inch bays a aluminum sheet going over that and a few more things need to b done like the middle shelf more vinyl more holes and stuff so yeah it is going aight but the case you either hate it or love it its like with a lot of cases out there
Right then BIG UPDATE um scan are still taking the piss with my order waiting on 5 items that should of been in stock there saying the 1 mobo water block and the 2 gpu water blocks are in stock on the 14th and the graphic cards they don't know when so i thought since i aint posted on here in a lil while i give you the HARDWARE PORN LIST that im waiting on ....
1) Corsair Vengeance 2000 Wireless 7.1 Professional Gaming Headset + MIC, USB 40 Feet Range & up to 10 Hours Battery Lif
1) 16GB (4x4GB Corsair DDR3 Vengeance Blue, PC3-14900 (1866), Non-ECC Unbuffered, CAS 9-10-9-27, XMP, 1.5
1) Intel Core i5 3570K,1155, Ivy Bridge, Quad Core, 3.4GHz, 5 GT/s DMI, 650MHz GPU, 6MB Smart Cache, 34x Ratio, 77W, OE
1) EK-Supremacy - Acetal - Universal Water Block ( CPU BLOCK )
1) Asus MAXIMUS V EXTREME, Intel Z77, S 1155, DDR3, SATA III - 6Gb/s, SATA RAID, PCIe 3.0, DP/ HDMI/ Thunderbolt, E-ATX
1) EK-FB ASUS M5E - Acetal+Nickel - Complete Liquid Cooling Solution for ASUS Maximus V Extreme Motherboard
2) 3GB MSI Radeon HD 7970 Lightning, 5600MHz GDDR5, 28nm, GPU 1070MHz, 2048 Cores, 4x mDP/ 2x DVI
2) EK-FC7970 Lightning - Acetal+Nickel, Water Block for MSI Radeon HD 7970 Lightning Series VGA
1) 1200W Corsair Digital AX1200i Full Modular, 80 PLUS Platinum - 92% Eff', EPS 12V, 1 x 140mm Fan, ATX PSU
1) 128GB OCZ Vertex 4, 2.5" SSD, SATA III- 6Gb/s, Indilinx Everest 2, MLC, Read 560MB/s, Write 430MB/s, 1GB Cache, 90k IOPS
1) Asus ROG Xonar Phoebus Soundcard and Audio Control Box
1) Gigabyte Osmium Black Mechanical Gaming Keyboard Cherry Switch with USB 3.0 Port
1) Gigabyte Krypton Dual Chassis Gaming Mouse, 8200dpi, black
6) 120mm Corsair Air Series SP120 High Performance Edition, High Pressure, 2350rpm, 62.74CFM, 35dB, 3-Pin, Twin Pack ( total of 8 fans but i only need 6 since im going for 2 x 140 rads but no point changing it because i just give 2 fans to my step dad as he running 2 shit fans in push and pull on my old h50 xD)
1) EK-CoolStream RAD XTX 360
2) 140mm Corsair Air Series AF140 Quiet Edition, High Airflow & Low Noise, 1150rpm, 67.8CFM, 24dB, 3-Pin, Single Pack (yeah need to get 2 more shame they don't do them in SP140 :P )
1) SteelSeries QcK Mass Mouse Mat, 285 x 320 x 6mm
1) 512GB OCZ Vertex 4 M 2.5" SSD, SATA III, Read 560MB/s, Write 510MB/s, 120k IOPS Max
So there you go guys thts the hardware list let me know if i should change anything while im wiating for pre order stuff many thanks chris
sounds promising :)
but the psu is massive overkill... the 760i would be more than enough...
i'd change the ssd brand if it was my build... get a samsung, intel, corsair, crucial...
and go for 2133 ram or higher ivy loves it :)
sounds promising :)
well i can allways oc the ram and its only 1866 ghz wich is more then enough with 16 gb of ram and the psu may b overkill but i am running like 2 pumps leds neons 2 gpus OC the shitttttt out the cpu gpus and i understand about the ssds but there way faster im more of the read type then the price type tbh but ye thanks for your opinion but like i have my opinion and its nice to have some one to say whats on there mind so thank you
yeah forgot i took pics of the middle shelf bracket front side and then the bottum took of them bends for the sound proofin and vinyling and decided to take the case completley apart for the 140 mm holes and three 20mm holes for the back panul and the bottum panul i need psu hole cut out and 2 120 cut outs :) all fun xD :cool:
The SSD is more to be on the save site, OCZ have some problem to stay a life. And that is all ;)
OCZ are known for not making the most reliable products (SSDs, PSUs, etc)
I think most people on this forum would agree.
It's just better to go with an Intel, Samsung, Corsair or Crucial
well 320 quid for 560 read 512gb ocz vertex 4 i cant complain tbh thats just right space i need for games and the 128 gb ssd one for 90 quid just for the os i cant complain tbh guys you lot got me worried now hahaha :D
I must admit the speeds are good, but they're just not very reliable. In the end its your choice but I'd personally rather spend a tad more, or even use somewhat slower drives over buying an OCZ drive :)
well im going for price i cant realy afford like over 500 quid just for like 400 - 500 gb of corsair b enice but for 310 POUNDS for 512 gb of 560 meg read sata 3 6 gb i cant refuse xD as im more focos on the board psu gpu and cpu :)
nice progress mate
thanks bud its getting there just hard bit is making them bends that the orginal mobo tray has to the aliminum cant be a fraction out and um i never done bending people say use a soft mallet all advice i got kinda worried realy but i got some sound proofing 3mm thick stuff wicch will cover up the out side / inside rivets holes dimps when the vinyl goes on top get my drift :) so im gonna sound proof the in and outside of the beast xD hehehe but like i said its gonna be a slow build as its only me doing it and this is the first time i have took a case apart and got realy stuck in i just left it but in my head what i wanna do with my hardware and water cooling i need to make it for that idea confusing i know sorry am trying hehehe :lol:
