I recently got a 7800GTX and its really playing up, when i first installed it it lasted about 5 minutes on need for speed then locked up. thought it might of been my overclock so took that back to default and tried again, locked up after 10 minutes of 3dmark.
Reseated the card and wiped the strip, checked all the power connections powered back up and managed to loop 3dmark for a good half an hour or so only to have it lock up within 5 minutes of medieval II.
Spec of this PC...
Opty 144 - 2.8 (returned to default to test)
1 gig corsair
DFI SLI-DR
2x 250g sata maxtors
Tagan TG530-U22
I know its easy to blame the psu but the 530 tagan should be capable shouldn't it? i only ask becuase it wouldn't even boot at first and i checked the switch and had to switch it to combine the rails just to get it to boot. My Voltage rails seem quite off as well but have only checked with software, will get a multimeter over the weekend.
also the card is watercooled on a temporary loop of its own (had no aircooler for it) so used a DD nv78, 1250, 240 rad. Temp is idling at 35.
any idea's what i could try? and does anyone else think it may be the PSU?
Cheers
Spec of this PC...
1 gig corsair
DFI SLI-DR
Tagan TG530-U22
Cheers
