570TRIX (modded Corsair 570X) by SimpleModz
ciobanulx
Hi guys,
Welcome back to another one of my build logs! This time I am working on the newly released Corsair Crystal 570X tempered glass case!
I would like to thank everyone at Corsair for giving me the opportunity to work on this case as I know this was sent to a group of elite modders world wide! I'm simply honored to be considered for this and see myself up there with the talented people that I look up to and inspire my work!
The 570X is a case with tempered glass on pretty much all sides and it's truly a stunning case. My build will be all about elegance and luxury as well as drawing a bit of inspiration from the crystal series name.
SPECS:
Case – Corsair Crystal 570X
Motherboard – TBA
CPU – TBA
Memory – 4 x 4GB Corsair Dominator Platinum 3000Mhz DDR4 RAM
GPU – TBA
SSD – 240GB Corsair Force LE SSD
PSU – TBA
Custom Cables - CableMod
Cooling
Corsair H100i V2
Corsair HD120 RGB Fans
To start off the build log I did a quick unboxing presentation of the case. I hope you guys enjoy it and stay tuned for more!
https://www.youtube.com/watch?v=aYUFvNUE-CU
Cheers,
Alex
Hey guys,
Time to start making some progress on this build so I started stripping down the case.
Next step will be to fully take it apart by drilling out all the rivets however I need to work on some things before.
More to come :)
A great thing about the 570X is that you can take both the front and top fan/rad mount out by just undoing two thumb screws.
This then leaves the top and front fully open.
Stay tuned for more!
Cheers,
Alex
Hey guys,
I've been working on my design for this build and ended up cutting a lot of acrylic for it.
Here's the near entire pile hahaha. I'm still working on my idea and refining it but I think it should turn out pretty nice.
Different panel sections that I am working on
This will be on the back to hide some cables and the rest will be displayed nicely behind the motherboard tray through the tempered glass panel.
I have them numbered and named hahaha as there are so many of them.
Thanks for checking it out and stay tuned for more!
Cheers,
Alex
Hey guys,
I've started to take apart the case and get it ready for painting. So many rivets!
Cheers,
Alex
Hey guys,
The custom paint for the main panels is now finished! The parts that are still black are scuffed as I was going to do them silver as well however I decided to leave them and it works out better this way. I will just need to re-spray them black now in order to fix up the scuffing.
Anyways, let me know what you think so far! Stay tuned as there's more to come!
Thanks for checking it out!
Cheers,
Alex
Hahaha well... you didn't guess the colour. Anyways, new update is now up. Let me know how you like it :D
I just hope its some metallic paint colour. Because those just pop and look amazing when applied properly.
Gloss and satin are nice, but nothing beats a good metallic tint.
It is a nice metallic with some nice sparkly flakes in it, not sure if you saw it as it's already up :D
Hi guys,
Merry Christmas! Just wanted to do a quick update on the build :)
With the majority of the case work now finished I will have to turn to the smaller details now and you guys will get to see that in due time.
Before that I want to showcase some of the components, the new H100i v2 and the Corsair HD120RGB fans. I am very excited for getting to use these fans :D
I'll have more updates in the new year or sooner if I can :)
Cheers,
Alex
Hi guys,
A quick update on the PSU shroud design I am doing :)
Just needs a bit of a clean up and some clear coat :)
Cheers,
Alex
Hi guys,
I have a few more photos to share on the project however beyond this point I can't really share much due to NDA stuff. The build will be finished shortly and very soon I will be able to show everything so stay tuned.
I have most of the core components in at this point. I just need to finish the rest of the panels for the case and a special effect for the outside glass panels. Half of the cable management is done as well with all the fans and H100 cables sorted. There will be a cover panel going over this area which I shared before.
Cheers,
Alex
