3DMark Scores
stocky
I have just run 3DMark03, and got a score of 31645. I'm just wondering if this sounds about right for a system with the specs shown below on air?
AMD X2 4800 @ 2.8GHz (11 x 255)
7800GTX SLI @ 524/1391
Is it possible to get more with this stock cooling setup?
For the clocks you are running stocky mate, coupled with the what you are running the cards at seems to be very reasonable.
Are you tweaked to the max?
Mav
I doubt I'm tweaked to the max - I have followed what I could find...
LOD = 15, then slider to 4.
All set to high performance in display props. and AA, AF off.
BH-5 at 2225, as per your BIOS DRAM settings.
Anything else you can think I've missed, as you are known as the master tweaker! :D
Have you tried playing with priority from the C-A-D processes box?
Err.... PCI-E frequency?
Windows stripped?
How are your RAM subtimings? Prob make more difference to Pi than 3DMark, but every point helps
K
Computer Aided Design?!
PCI-E = 113 (I think)
RAM timings are the same as Mav's BIOS shot for BH-5...
Does this A64 tweaker do anything handy?
What XP things should I play with? - how stripped?
Sorry...C-A-D means (in my little world) Control-Alt-Delete coz its easier to write out.
I disable everything in MSConfig for benching, but a couple things need to be left for 3DMark06 and PCMark05.
A64 tweaker rocks for in windows RAM tweaks- set yourself an evening aside and play with it. It`ll help a ton for SuperPi, which is...errr....not what you`re trying at the mo. Dooohhhhh
