3DMark 2006 Scores: Show It Off!
For xmas im hoping to get water cooling. Was kinda hoping there would be some info available on whether 7950gx2 quad sli is going to work on vista 64, since apparantly a 4way AFR was going to be invetned on Vista to make the quads work loads better, I think ill get water cooling for my current rig instead though, its pretty loud. Ill replace my current fans with low RPM quite fans.
It'll be good beacuse it means some serious overclocking!
name='Mr. Smith' said:
Well mate, your cpu is probably holding you back - I think I got a couple of thousand points from overclocking (cpu - also gfx/ram oc'd)...
I take it you have the latest drivers?
Hi .. i've just upgraded my mobo and cpu following your advise here .. problem is i think my 3dmark score is still a bit low compared to my hardware it's now (10013) .. please advise if this is a low score ,i'm running windows vista ultimate 32bit with this specs at stock clock..
intel Q6600 (2.4 quad-core)
XFX GeForce 8800GTX (forceware 163.69)
XFX 680i SLI LT mobo
2GB of bus 667 ram
hec 650w psu
lots of hard discs but all of them is WD 7200 rpm
Sound on board
sorry about my english coz i'm not a native speaker of english
Friend just did 3dmark on his new rig. on XP
Q6600
ASUS P5K-E Wifi
2gb Patriot
500GB Seagate
XFX 8800GTS 640mb Extreme Edition
OCZ 700watt PSU
he just ran it all at stock, except GPU and got 10105
sm2 is 4035
sm3 is 4136
cpu is 3812
he just did it again with his quad at 3ghz, on stock volts! (gotta love that SLACR)
10546
cpu 4725
sm2 4077
sm3 4203
i think his scores at 3ghz should have gone a little higher
My rig is:
E6600 @ 3.6ghz
4GB PNY XLR8 DDR2/800
2x PNY 8800GTX @621mhz core, 1000 mem SLI
500gb Maxtor HDD
EVGA 680i Mobo
Gigabyte Odin GT 800w power supply
_________________________________________________
3DMark Score 15806 3DMarks
SM 2.0 Score 7315 Marks
SM 3.0 Score 7909 Marks
CPU Score 3226 Marks
Detailed Test Results
Graphics Tests
1 - Return to Proxycon 59.796 FPS
2 - Firefly Forest 62.125 FPS
CPU Tests
CPU1 - Red Valley 1.019 FPS
CPU2 - Red Valley 1.634 FPS
HDR Tests
1 - Canyon Flight (SM 3.0) 80.897 FPS
2 - Deep Freeze (SM 3.0) 77.278 FPS
Q6600 and custom water cooling on the way!
I think your CPU lets your score down a bit there mate, might be worth getting a quad core, new ones come out soon.
For all that GPU power quad core must be tempting :D
ya the cpu bottleneck is killing me, but I have a Q6600 G0 and all my liquid cooling parts on the way
Hope I can get quad to about 3.6..
will be v. interesting to see how 8800GT performs in 3dmark06, it might be used to get the new high record in SLI ya never know.
I hit 12k score with 3d mark 2006 I cant remember the exact number thought. I have a Q6600 and a geforce 8800 OC to 3ghz GTS overclocked even more by me
Well I'm ordering the Zotac 8800gt AMP! edition which is 700/2000/1700 for core/mem/shader and from what Ive seen with a 3ghz quad it gets close to 13k in 3dmark06, so will be cool to see what I get with it.
