3DMark 2006 Scores: Show It Off!
Just overclocked my 7900 gto and raked in 6766. The Q6600 is almost 4 times (well duh...) better in this than my 902 3d marked 3700+ athlon.
Main Test Results
3DMark Score 6766 3DMarks
SM 2.0 Score 2685 Marks
SM 3.0 Score 2538 Marks
CPU Score 3405 Marks
8800 gt would push this well over 10~11k I imagine :)
Links in sig. I was hopeing for more outta this 8800 GTS but I didn't get it. I really need a CPU upgrade and maybe the new 8800GT.
Most of these were ran with clocks of 650/2000 on the GPU.
For a dual core and a 8800GTS.. that really is a damn good score, you should be proud of that.
Someone will always have better hardware, the goal is to make the best use of your current tech instead of going and buying new things.
Spot on matey! :)
No need to spend spend spend to be the best. Save save save and be the best!
I see alot of people with Dual cores and 8800GTS and they are hitting 13K. Maybe there CPU's are @ 3.5-3.6 to get thoes scores but mine just seems low.
Cheers for the aproval to post on here :)
This is my current best score..
Thats with the cpu at 3ghz on stock voltage, the 8800gt at 725 core, 1750 shader and 970 memory.
Very pleased to break 14k!
[hwbot] 11532 - Intel Core2Duo e6300 @ 3230MHz - Geforce 8800gt @ 600/900 - OCZ Special Ops @ 5-5-5-15 - Asus p5b deluxe[/hwbot]
Here's my score:
http://service.futuremark.com/compare?3dm06=6800513
http://www.hwbot.org/result.do?resultId=738046
3DMark06 Score - 17819 3DMarks
SM 2.0 Score - 8090
SM 3.0 Score - 9227
CPU Score - 3560
These results are with the CPU OC'ed to 3.96GHz, and the GPU running at stock. I am going to try OC'ing the GPU later today and if there's any improvement I will update.
Cheers,
Stu
EDIT: Run 2 with further CPU & GPU Overclocking:
I upped the CPU to 4141MHz with a 460MHz FSB, RAM running at 1:1 (460MHz) and the GPU to 725/1140MHz and ended up with this result
3DMark06 Score - 18752 3DMarks
SM 2.0 Score 8404
SM 3.0 Score 9685
CPU Score 3813
http://service.futuremark.com/compare?3dm06=6808327
http://www.hwbot.org/result.do?resultId=738061
finally i can post :)
my 3dmark '06 score is 16544 3DMarks
This is on my new hardware, QX9650@3GHz 4GB ddr2 and 9800GX2
Will post other benches when i get the progs
UPDATE: Make that 17114 :)
Just to say I can't seem to send verification to the hwbot site for some reason the site is giving the exclamation mark to IE.
19115 aint too shabby but im still very bodge-tastic at the moment once I get my TJ07 and mount everything properly (not with duck tape) I should see better temps and therefore be able to up it again :D
Updates
My new benches are in me sig now and all updated... just waiting to get some ddr3 10666 to help me lift the ceiling on my fsb thats limited by the ddr2... :):wavey:
Figured I show you my attempt progress. I will break 20k before next nVidia GPUs are out and if I don't I won't buy them so this is important.
Q6600, 8800GTX in SLi, 2Gb PC3-16000 (not being nice currently)
Score CPU-Z Validation and GPU-Z validation
Picture of score
19683 CPU-Z GPU-Z
1st Picture
20057 CPU-Z GPU-Z 3DMark06
2nd Picture
hey all...
hey thought id post my Asus EN8800gts 512 G92 with self modded bios....
cant seem to get it past these clocks by anymore than about 4mhz before i get a few small yellow dots with Atitool.
Hoping to contribute to this soon : ) Just need to install a new OS and for some reason 3dmark06 isnt working on this one. Dunno why. Oh well. high scores coming soon I hope : )
Well my score was 18k but with an extremely quick +1 to the multi and a little extra voltage I managed to brake 19k :D
Not too bad. Should be able to brake the 20k mark tomorrow when I push CPU a bit higher and actually give my cards an OC. Damn ccc...
