2900pro in loop
woppy101
could i put a 2900pro in to my watercooling loop at the min i am cooling a 6000+ 33c idle 39/41c load i have
PUMP 12V Laing DDC-1T Pro w/Petras Tech top
RAD xspc 240 thinking o changing to a Black Ice GT Stealth II on upgrade
1/2 id hose
will it handle the heat output of a 2900
many thanks
BlackIce GT Stealth won't be an upgrade from your current rad - just a sidestep to a different brand. If upgrading, it's only worth it if you upgrade in terms of a fans' worth of surface area... ie: from a 120.2 to a 120.3.
