What Pump For This Loop?
ruthless_villain
Hi, so im almost ready to buy my loop but have one question what kinda pump shall i get?
it is only going to be a cpu and gpu loop and i will be using dual rads (360 + 240)
im not sure what video card im going to get yet
but it will be a
XSPC RASA BLOCK
W/E gpu i get full cover block
Hardware Labs Black Ice® GT Xtreme Lite 360mm Triple Radiator : GTX360-LITE
Hardware Labs Black Ice® GT Xtreme Lite 240mm Dual Radiator : GTX240-LITE
and a bunch of bitspower barbs etc
i will sli the GPU in the future so need to think about future proofanisation
now to the part im stuck on initially i was thinking about getting this:
http://www.specialtech.co.uk/spshop...a-Acrylic-Reservoir--X2O750BAY-pid-10479.html
but then i read something that made me think it would not be adequate for a dual gpu config so i looked at this:
http://www.specialtech.co.uk/spshop...-XSPC-Reservoir-Top-Bundle-Deal-pid-6647.html
and then i saw Mr.Logan use this in one of the GSL rigs and i thought about this:
http://www.specialtech.co.uk/spshop...DDC-Ultra-18W-Pump-Bundle-Deal-pid-11202.html
now ofcourse i know which one is better but which one is adequate and will do the job without being stressed too much
thanks for any input much appreciated
True about the D5 has a lower head height but a 3/8 655 will still be behind the D5. The best performance for multiple gpu set up wuld be a seperate loop. If you are not financial restricted
