So having recently come into some money, i've decided along with a graphics card upgrade i might as well go for a full custom water loop to replace my coolit ALC system.
(relevant)Hardware I plan to water cool
Case: Cooler Master Cosmos 1000
Processor: i7 960 OC to 4GHz
Graphics: Radeon 7950
So far I've got this system down (I was going to post a screenshot but apparantly images aren't allowed? wut?):
Powercolor HD 7950 3072MB GDDR5 PCI-Express Graphics Card
EK-FC7970 Full Cover Waterblock - Nickel Acetal **EN Nickel Plating**
XSPCX2O 750 Dual 5.25” Bay Reservoir Pump (Ideally want reservoir in 5.25" bay and with an integrated pump)
XSPC RayStorm CPU WaterBlock (Intel)
Hardware Labs Black ICE GT Stealth 240 Radiator
Phobya G-Changer 120 Ver. 1.2 Black
Noctua NF-P12 Vortex-Control 120mm Quiet Case Fan - 3 Pin
Masterkleer Hose Pack PVC 16/10mm (3/8ID) UV-Reactive Blue 3,3m
Mayhems X1 UV Blue Premixed Watercooling Fluid 1L
Mayhems Fine Silver Kill Coil
OcUK 3/8" G1/4 - High Flow Style - Shiny Silver- Compression Fitting (x10)
I was thinking of getting a phobya 60mm deep 240mm radiator for the top, but after checking the measurements it just wouldn't fit. I plan to mount the 120mm fan at the bottom of the case where an intake fan is currently.
Am I missing anything, got anything majorly wrong?
I've tried to research around this as much as I can but i always find responses to specific situations much more helpful
Cheers
Cheers
