Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section > OS & Apps
Thread Tools Display Modes
  #1
Old 16-07-19, 05:19 AM
Dawelio's Avatar
Dawelio Dawelio is online now
OC3D Elite
Windows 10 Pro activation
Heya guys,
So probably a rather dumb question for you all, but I’m a bit stuck... So I just switched to AMD from Intel and earlier I just had to call up Microsoft Activation Center and then get through the automatic process, get my Installation-ID, wait for the voice to give me my key and done.
Now I see that that option is no longer available and tried finding the correct way to contact support, but I just keep being directed to different pages on Microsoft Support site and end up going around in circles.
So now my question is; how do you even activate your license key (without having to call abroad, which costs a lot)?
Thanks,
Dawelio
  #2
Old 16-07-19, 05:35 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Microsoft have a free call number in your country justt google microsoft free support number
in Aus it's 132058
Yours is +44 (0)344 800 2400
__________________
DRAGON'S MIST
Coolermaster H500P White ARGB=AMD Ryzen 3700X=MSI Prestige X570 Creation=Intel Optane SSD 9 480GB PCIE=32gig 3600Mhz White Dom Plats RGB= Sapphire RX5700XT Nitro Plus=Coolermaster ML360R ARGB=MSI Optix MPG341CQR=Roccat AIMO 122=Corsair Force LS 960GB=Roccat Kone AIMO White=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with RBG strip=Windows 10 Pro=Thrustmaster T16000M HOTAS=Razer Firefly RGB CE=Chasepower Pure Sinewave UPS
  #3
Old 16-07-19, 05:36 AM
OC3D Elite
sorry that's UK this is in Sweden+46 (0)8 55 99 00 00
__________________
DRAGON'S MIST
  #4
Old 16-07-19, 11:35 AM
Dawelio's Avatar
OC3D Elite
Yeah, I found that... The issue is that still uses and wants an Installation-ID, which is no longer available through the activation page in Windows. Hence the issue and this thread.
  #5
Old 16-07-19, 12:20 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
What happens when you enter the key again?
Which type of key do you have? Cheap £15 or so or retail?
The cheap ones are no longer transferrable as they are single use only. If you have a retail you can use it on four machines IIRC.
You have the license key written down right? Otherwise it's now a part of your old board. If it was a cheap Amazon jobby you'll need to buy another one. Also did you reinstall or change the board with the existing installation in place?
__________________
If you don't like what I post don't read it.
  #6
Old 16-07-19, 01:21 PM
Warchild Warchild is offline
OC3D Elite
I'd say just buy a win10 pro key and then not have to worry about this problem again.
They gave us all a chance for a free upgrade which was nice. But that ship has sailed. I picked one up for 180Sek and found it was worth it than trying to reinstall 8 and upgrade from there etc.
Alternatively, call microsoft free line and ask their advice. Perhaps there still is an option, although not as transparent as before.
  #7
Old 16-07-19, 02:11 PM
Dawelio's Avatar
OC3D Elite
It says it’s already in use on another device (my old Intel motherboard). I have an legit £200 retail Pro key, with package, disk and everything. So yeah, the license key I have on this little greyish Microsoft badge that used to be on the bottom corner of prebuilt systems before.
  #8
Old 16-07-19, 03:38 PM
AlienALX's Avatar
OC3D Elite
Then you should be able to input the key and it activate etc etc.
They have changed things a bit. It was to stop these cheap keys being abused. Now they are only single use, and the last time I activated one the Indian guy said it was the last time... It also sounds like they have closed down said Indian call center, so god knows now.
__________________
  #9
Old 16-07-19, 03:46 PM
Thelosouvlakia's Avatar
Thelosouvlakia Thelosouvlakia is offline
Classy-Fried-Chicken
There is a "call me back" feature on MS support site. Or you can call them yourself. If you have a retail key they will activate it for the new motherboard you have at least that was their policy 6 months ago I had to call them myself
  #10
Old 16-07-19, 10:33 PM
Dawelio's Avatar
OC3D Elite
Everything worked just as usual after a reinstall of Windows on the new motherboard and doing all of the Windows updates to the latest version. Called the automatic process and all good now. Thanks everyone for your help and input!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
