Thread Tools Display Modes
  #11
Old 14-01-14, 08:50 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Is the original case an Apple case ?
__________________
=AMD Ryzen 9 - 3950X + PBO - XFX 5700XT Thicc III Ultra @ 2100/1800=
If you think about it, VR is free unreal estate.....
  #12
Old 15-01-14, 06:05 PM
Shaw's Avatar
Shaw Shaw is offline
Newbie
I went pretty overboard with the 90° fittings on the back, purely for aesthetics. The case has a glass window on the back so I might as well make use of it.
And here's a render I forgot to add:
Due to the direction the motor spins the inlet and outlet are on the wrong side for what I need, and the fitting is too wide to fit directly into the res so 2 45° fittings are needed. as well as the 90°s and extensions.
__________________
  #13
Old 02-02-14, 06:15 PM
Shaw's Avatar
Newbie
So it's been a long time since an update, but I decided to sell my current build and start fresh with this one - it's been much harder to sell my old PC to fund my new one than I thought it would have been, but hopefully updates will be a little more frequent now.
The new specs will be pretty similar: GTX 770s to replace my 680s, a 3930K to replace my 3820, and keeping the same board and RAM.
As for this update, I received a nice little package from Nils:
But what's in the bag…?
A crimping tool!
and…
Crimps!
This time round I'm going all out and making my own custom cables. With the windowed side panels on both sides of the 904 case, I want everything to be perfect.
As for the sleeving.. well…
PINK!
And a nice little Ducky Shine III to match:
(Still awaiting arrival of some PBT side etched key caps.)
Hopefully I'll have some new hardware to play with next week so I can get started on the case mods.
__________________
  #14
Old 01-03-14, 09:37 PM
Shaw's Avatar
Newbie
Update time!
I've got my hands on most of my components now - just waiting on my radiators, fittings and tubing. Fittings wont be here until at least the end of the month but hopefully I can get everything ready for then.
I haven't really started anything yet as I'm waiting for my rads so I can start modding my case.
So here's the parts I have up to now:
And I'm going to steal some photos from my old build log as these items are being carried forward - just pretend that's a 3930k and not a 3820.
Thankfully I don't have to polish those caps all over again..
And there was no way in hell I was selling my MIPs IceForce High Flow water block! Such a shame to see MIPs go out of business.
Also didn't want to sell these beauties as they run at 2000MHz 9-10-9-24 T1
Now onto the new parts:
Replacing my old 680s with pretty much the same cards - GTX 770s
My old budget sound card died so I had to go back to using on board and, man, have my ears been spoilt. Couldn't go back to on board sound again so thought I'd upgrade to a pretty tasty Creative Titanium card.
As much as I loved my old Gelid Wings, they weren't silient. These are.
Pump top and reservoir from Aquacomputer. Really nice build quality and aesthetics. Those plugs on top of the res are about 1mm too tall to fit in a drive bay, so I'm either going to have to find some lower profile plugs or shave the tops of the ones I have.
And of course, some pink.
The Pastel pink from Mayhems looks quite milky. I'm probably going to buy some red dye to try and turn it hot pink like my parachord.
As soon as my radiators land - hopefully next week - I'll be able to crack on with the case mods and installation.
__________________
  #15
Old 01-03-14, 10:10 PM
mod_ex's Avatar
mod_ex mod_ex is offline
Member
loving the look of this, very well thought out will be keeping my eye on this well done so far..
  #16
Old 04-03-14, 08:35 PM
Shaw's Avatar
Newbie
Thanks mod!
I can start to get to work on my build no that my rads have finally come!
I went with Alphacool because of the multi-port options:
Only problem is the plugs that come with the rads are copper - those will be getting sprayed black. Nice to see them ditching the ugly copper stickers too - last time I removed one it peeled half of the paint off with it.
I'm going to have to get some longer M3 screws before I can stack my rads.. The only screws I have the right length are M4.
I've said before that this build is going to be incredibly tight...
I can now confirm just how tight it will be:
Tight.
I had to remove the cooler to fit the card in, so those of you under 18 please cover your eyes for the next picture as it contains full frontal nudity.
Best get her covered up, back and front!
I have to say, those water blocks and backplates are what sold me the 770s. The fullest full cover blocks out there and they just look so clean. None of that circle crap EK tried to pull off in the past.
__________________
  #17
Old 04-03-14, 08:55 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Still really interested to see this finished, as like my case you can see everything inside can't wait to see your cable management.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #18
Old 04-03-14, 09:25 PM
sheroo's Avatar
sheroo sheroo is offline
OC3D Elite
Looking lush fella - keep those updates coming...
__________________
"All his life has he looked away... to the future, to the horizon. Never his mind on where he was."
  #19
Old 05-03-14, 01:31 AM
MadShadow MadShadow is offline
OC3D Elite
Looks really nice, keep it up!
__________________
|i5 4460|16GB RAM|R9 380 4GB|ASUS Z97-I Plus|WD Blue 1TB|Corsair RM650|Phanteks Enthoo EVOLV ITX|
  #20
Old 05-03-14, 07:57 AM
tinytomlogan's Avatar
The Guvnor
getting interesting!
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
