Go Back   OC3D Forums > [OC3D] Processors & Platforms > Overclocking
  #1
Old 04-06-09, 03:25 PM
BiscuitCookie BiscuitCookie is offline
Newbie
Overclock doesn't want to work
I have a E8400 which I want to OC to 3.6 ghz
but every time I change something in the jumperfree configuration menu it says on start-up "Overclock failed or Overvoltage failed"
Using Asus P5QL-CM motherboard
btw overclock software won't even get my fsb
  #2
Old 04-06-09, 03:28 PM
Mul. Mul. is offline
Advanced Member
Did you raise the FSB from 333 to 400 in one shot or did you overclock in steps? Did you adjust your memory frequency at all?
  #3
Old 04-06-09, 04:25 PM
Newbie
I tried in steps and tried in one shot also tried the auto overclock profile of 20% and everything in between(5, 10, 15)
and if I leave everything at default it just boots up and if I set ai overclock to manual it also just boots up
adjusted memory frequency to 667 so when I overclock to 400 it is on 800
  #4
Old 04-06-09, 04:30 PM
rapidman17 rapidman17 is offline
Advanced Member
Have you touched the voltages atm?
Can you post up all your current voltages...fsb..multi etc..
  #5
Old 04-06-09, 04:35 PM
Newbie
all the voltages at default
333mhz fsb
9x multi.
ratio 5:6
1.8 volt for memory
1.072 volt cpu idle
  #6
Old 04-06-09, 04:42 PM
Advanced Member
Yh i mean can u post the voltage readings? something like cpu-z will giv you core voltage and mbm should help:
http://www.pcworld.com/downloads/fil...scription.html
  #7
Old 04-06-09, 07:10 PM
Newbie
mbm doesn't want to work for me comes up with something in the config wizard with the settings.dll
but I already gave the vcore which is currently (idle) 1.07v
  #8
Old 04-06-09, 07:20 PM
Ian Evey Ian Evey is offline
Newbie
All i did was had everything on auto except fsb which i manually changed to 400mhz and that was it. I have a p5ql pro p43 but i suspect the bios settings are the same.
You really need to see how much the voltages rise when you raise the fsb it could be not enough cpu voltage ( vcore ) or not enough northbridge voltage ( NB ).
You could try setting cpu voltage to 1.3 manually with no other settings changed and see if it boots?
My cpu voltage is 1.128 at 3.6ghz on load and idle is 0.936 with speedstep enabled and everything else is on auto in bios.
Yeah MBM does not work for me either.
Ian...
  #9
Old 04-06-09, 11:46 PM
alexhull24 alexhull24 is offline
Advanced Member
Sounds like your Vcore is too low, i'd try upping it to 1.2 or something, then if you're happy with the OC and it works, get it down as far as possible. The E8400 should be good for up to 1.35V relatively safely, though I very much doubt you'll need to go that far if it's an E0 stepping.
  #10
Old 05-06-09, 04:10 AM
Newbie
but where do I adjust vcore because it only gives me options like 50mv, 100mv and 150mv in the jumperfree configuration menu
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
