Go Back   OC3D Forums > [OC3D] Hardware & Software > Networks & Security
  #11
Old 14-12-20, 12:32 PM
Gothmoth Gothmoth is offline
Advanced Member
it was the same when copying under linux.
but i think the issue was this:
ps:
there is one more thing i have to check.
when testing the card i screwed it in when using the bottom slot. because it should stay there.
when using the second x16 slot i just put it in but did not screw it on.
i did it so each time i tested the different slots.
i just noticed, that when i screw the card in the card moves a tiny bit. because the slot shield (sorry i am german donīt know how itīs called in english) is bend a bit. so the end of the card moves 1-1.5mm up when screwed in.
it seems to sit fine in the PCI slot but maybe the connection to one or two of the pins is not 100%.
??? could this be the reason? should i not get more error messages in that case?
i put the card in without screwing it in and no issues.
then i bend the card bracket a bit, so that it does not move at all, screwed it in.. no issues so far.
i will do verify for while to be sure, even when itīs slower.
make me verify that the configs are compatible - but I've never used mellanox gear, or any serious networking gear on Windows so take that with a grain of salt.
that some kind of extra feature these cards offer that i donīt use anyway.
but i found no way to disable it.
it should cause no issues. itīs just a fallback to an earlier version of that feature.
__________________
2x TR 2950, 1x 3700x, 1x 3900x, 1x 5900x
2x Eizo CG 2730 1x Eizo CS 2740, 1x BenQ PD2700U
  #12
Old 14-12-20, 01:06 PM
FTLN FTLN is offline
OC3D Elite
Good to hear its working !
  #13
Old 01-03-21, 01:36 PM
Advanced Member
itīs working now since without an issue.
this was really a strange thing.
i build my own PC since the mid 90s but canīt remember having such an issue.
i may had a GPU that did not sit correctly in the PCI slot but then it was not working at all.
the rear of the networkcard really only moved a tiny bit up when screwing it in.
i only noticed it by coincidence.
but it must have been enough to compromise the connection.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
