Go Back   OC3D Forums > [OC3D] Cooling Forum > Cooling - Other
Thread Tools Display Modes
  #81
Old 23-01-18, 12:21 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Originally Posted by Eddie long View Post
Quick question
Is it worth sticking purchasing 2 splitty 9 to go with my aquearo 6xt so I keep the component all the same manufacturer or would anyone surgest another option for a fan splitter hub ie xspc / phanteks ect that will work as well or better
TBH mate Splitty 9 are so cheap it's not really worth looking elsewhere.
__________________
If you don't like what I post don't read it.
  #82
Old 07-04-19, 12:37 PM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is offline
OC3D Crew
Hi all!
I'm using an Aquaero XT 6.
Currently have it controlling all fans in my case via the software.
I've been informed that saving the settings then unplugging the Aquaero from the motherboard should cause the unit to run independently, however, I tried this and the unit reverted to default settings.
When booting the fans run at 100%, then when my PC has loaded into Windows and the software starts they run at their controlled level, however, if I unplug the Aquaero they just run at full speed.
How do I get the Aquaero to save the settings then run independently of the software?
__________________
Enthoo Elite | i9-7900X | Rampage VI Extreme | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB, 840 Evo 250GB x 2 | EVGA SuperNOVA 1200 P2 | ViewSonic XG270QG, MX27AQ | Custom Watercooling Loop + Aquaero 6 XT
  #83
Old 07-04-19, 01:21 PM
AlienALX's Avatar
OC3D Elite
Does it have a battery?
__________________
  #84
Old 07-04-19, 01:28 PM
OC3D Crew
Powered by Molex.
__________________
  #85
Old 07-04-19, 11:35 PM
Warchild Warchild is offline
OC3D Elite
Strange. Mine holds the settings, nothing special in software either.
  #86
Old 08-04-19, 01:22 AM
OC3D Crew
Think it was cos I was using software sensors.
Have a water temp sensor wired into the unit so have changed it round. Should be OK now!
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
