Go Back   OC3D Forums > [OC3D] Hardware & Software > Storage Mediums
Thread Tools Display Modes
  #1
Old 15-02-20, 03:54 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
Nvme to PCIe card
I have crosshair hero VII, using 2 x nvme drives, however it appears that one of the 2 m.2 slots shares its lanes with the x16 card which means my meagre rx470 is running at x8 instead of x16.
Does anyone have recommendations for a cheap adaptor card for the nvme that will fit into one of the other pcie slots?
TIA
__________________
ASUS ROG Crosshair VII wifi | Ryzen 5 3600 | Antec 240 AIO | Corsair Vengance RGB 3200 2 x 8Gb | Asus Strix RX 470 | Samsung 500gb nvme | Samsung 1Tb nvme | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | Toshiba 1Tb HDD | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #2
Old 15-02-20, 04:12 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
https://www.ebay.co.uk/itm/283632257624
Noting you may have to move the GPU as it depends upon how the board is wired.
__________________
  #3
Old 15-02-20, 04:50 PM
WYP's Avatar
WYP WYP is offline
News Guru
TIA
I'd check if your motherboard even has a location where it can connect a PCIe add-on card without doing the same thing to your graphics card.
__________________
_______________________________
Twitter - @WYP_PC
  #4
Old 16-02-20, 12:17 PM
RobM's Avatar
OC3D Elite
Looking at Ronan's info I have 20 lanes coming from the CPU.
It would seem that using m.2_2 takes 4 lanes from the second gfx slot which in turn drops pcie 1 down to 8 lanes even when using 1 gfx card.
Whilst both of the x4 pcie slots and the bottom x16 wired as x4 slot are fed from the chipset.
__________________
  #5
Old 16-02-20, 12:45 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
The difference between x16 and x8 is maybe 1FPS, I wouldn't worry about it, Gamers Nexus did a whole article about it, The results are the same across the board, Below is Metro Last Light.
__________________
=Origin-Steam-Uplay-XBLive - Dicehunter=
  #6
Old 16-02-20, 01:34 PM
RobM's Avatar
OC3D Elite
Cheers Dice, I had forgotten that article
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
