barnsley
born in a.....
Either 13.12 is a really bad driver or I've got GPU issues :I. So a new problem has arrisen (the gpu shroud vibrating has fixed itself). Basically I was playing some sleeping dogs, which pushes my gpu to 97% usage and seems to be more of a stress test then any benchmark as its the first time I've seen it go to 70c. Basically the screen started to flash randomly and when I tabbed out to check the temperature it was on there was artifacts all over the screen, vertically. Memory temperature according to GPU-Z was 70c, the core itself was 70c so nothing was out of the ordinary. Since I last found out my GPU overclock was unstable its been running at stock.
So what should I do? Should I RMA it (and go get a 780 iChill), revert back to 13.11 or try and fix it?
