XSPC RayStorm
All that case and you kept that PSU!?
i would of gone Res-> Rad-> CPU-> GPU->Res.
That way you'd have no crossing over at all :-)
Ps.
Im struggling to work out what that is at the top of your case?
Well, that's really just the same layout in reverse.... But from a thermal perspective, yours WOULD be more efficient, so I take my hat off to you...plus you have experience on your side. :p :notworthy:
Oh, and I suspect that it is a second rad.... Based on the tubes heading up there. Just a guess though....
I'm running on the assumption that he couldn't afford both, so he simply picked one. Assumptions being what they are though, I could be well wrong.
You are correct though, that PSU should be the next upgrade...I just hope his gear all survives until then.
note: loop order makes little/no difference to temperatures at all. So long as your res feeds your pump, you're golden. End of story.
Just go for neatness, the rest is gravy.
