XSPC Rasa 750 RX360 vs Custom Loop
reeper250
Note that I have the Silverstone TJ02B case
The XSPC Rasa 750 RX360 kit is $200 but I will be selling the barbs, and tubing.
The RX360 rad would be mounted externally
If I was to go and build a custom loop it would consist of;
  • EK DCP 4.0 12V DC Pump - $59
  • XSPC Raystorm Waterblock - $79
  • XSPC EX480 Radiator - $85
Then there are three options for the res, which one is the best/needed;
I will be watercooling two GTX460's and either an i7 3700k or i7 3820
  • EK Multioption RES x2 150 Advanced - $49
  • EK Multioption RES x2 250 Advanced - $59
  • EK Reservoir for DCP 4.0 - $45
All up the custom kit will cost just under $300. Keep in mind that I will sell stuff from the XSPC kit.
I say go with the XSPC kit if you want to save the money, its worth it. If you dont need to save the money go with the custom setup. Its always more fun to make something yourself.
I ended up getting the;
Swiftec MCP355 pump
XSPC Laing DDC BayRes One
XSPC RayStorm
I still need to choose between these rads;
XSPC RX360 http://www.pccasegea...oducts_id=12559
Black Ice GTX 360 http://www.pccasegea...oducts_id=15730
XSPC EX480 http://www.pccasegea...oducts_id=18733
You cant go wrong with the xspc rx360.
