is there a possibility to fit the new Swiftech MCP35X into a dual bay res?
i see laing D5 and Alphacool VPP655 pump availabilty, but im thinking
the 35X is the way to go and possibly a dual/dual 35X at that (redundancy).
im looking to mount the dual res/pump(s) on the floor and thatll mean
ill be pushing a lot of hose length from floor of cm690 to the roof and
then to the cpu and back.
also, when i shut the system down, will the coolant fall from the cpu
exhaust line into the res and make an air pocket, or since its "sealed"
this issue is mute?
airdeano
this issue is mute?
airdeano
