paulstung
I've finally got my loop all connected, and I'm in the process off leak testing, but every time I turn off the pump, it keeps filling the res, and flowing back up into the top rad. When the pump is on everything is flowing as it should and is nice and quiet so doesn't sound as if there is any trapped air in the loop.
My loop order goes, res, pump ( DDC 3.25 900 ltr/ph, )up to top port on the front rad( 240 Monsta ) out of the other top port down to the EK dual parallel bridge ( side port ) GPU, GPU, then into the CPU block, out of the cpu block, into the top rad ( Ax 360 ) then into the top inlet on the res ( Aqualis eco 150ml ) The pump top is the Aquacomputer aqua cover pump top, and I'm using the side port as an input, and the top as an output, also between the res, and pump I have a Primochill flow meter, as I've had pumps die and like to see it is flowing, but this isn't full either, it is sitting about half full. This is set up as a straight in and out.
Any ideas guys ?
Any ideas guys ?
