A simple history log of this cases Journey over the last 12 months or so. Im between projects ATM so no ETA.
Where it began, I downsizing from a fugly full tower with side and front 25cm fans to something a little more simple.
The case arrives. Stock shot sorry
Sandbyridge upgrade thrown in in a slight hurry
Then the paint it,mod it, clean it up ocd starts...
Lil better but not enough
im eyeying the mesh up thinking, that needs painted.
New side panel arrives
Front mesh panels painted
and Top
Cable extension fitted and gromits made from ...mouse mats
Snapped the clips for the HS so I got a litte ghetto and did some painting too
200mm fan was lost in post for a lil while, forget to consider it..
Moar paint.
cable ties holding up
New HS, I won it
120mm bodged in the empty bays
I have a moment when i think, do I need moar?
Next up watercooling begins.
and Top
Moar paint.
New HS, I won it
