XFX 6870 Makes noise when pc is standing up
sakil7395
Hi Folks
I recently just finished a new build but there seems to be a problem with the graphics card. It always makes a noise like something is hitting it's fan. When I lay the case on it's side the noise goes away.
Does anyone know the cause to this problem.
Any help would be much appreciated
If not the cable it could be the bearing in the fan, if you could get a donor fan or a different cooler Arctic Cooling do some nice ones.
You could also take it apart and lubricate it, is tricky but works.
