X800PRO soft mod
does not work i have read many many forum threads on this alleged softmod, all the fro i mean french man has done is slightly modified the 9500 - 9700 and the 9800 se softmod the only benifit u will get is from using the new drivers (a couple of hundred points on 3dmark 03)
read this from the creator of riva tuner from rage3d forum
False alarm guys, this driver is an original driver patched with slightly modified SoftR9x00 for forcing X800 ID instead of 9500/9700/9800 modes available in the script. And it will not and cannot do the trick because pipeline count programming no longer depend on the PCI DeviceID on X800 family. And attempt to mod PCI DevID was the first trick I've tried after staring investigating X800 modability, and it doesn't change active pipeline number.
Anyway, anyone having the latest version of RT can reproduce the 'magic' without downloading whole driver by altering native SoftT9x00 script's code. The only altered thing in the script is changed PCI DevID override code. For example, to force x800pro DevID instead of 9800's one, just replace 66 0D 08 0E with 66 0D 09 0A in the script's [Common] section then patch the driver to get exactly the same modded miniport.
Summarizing:
1) It won't unlock pipes, because it's just PCI DevID overrider and PCI DevID don't affect pipelines count
2) It is a bit incorrect PCI DevID overrider, it forces X800PRO's PCI DevID, not X800XT's one. Probably the man behind the script modification didn't understood changes made by SoftR9x00 completely, to force XT ID he should edit AND mask too.
Damn, I was _so_ glad when W1zzard showed me that thread. I hoped that somebody else besides us tried to mod the driver and did it himself / found ATI's protections... Now the hopes are ruined. Damn.
__________________
Alex Nicolaychuk aka Unwinder, RivaTuner creator
