wolf in sheeps clothing........
badtaylorx
Member
i got this h60 at bestbuy when my zalman cnpps11x didnt fit my mobo.....it was just supposed to be a temp but check out my temps........and this is a 4hr+ prime 95 run........granted i keep my room at 19c but jeez!!!
setup
and here is my screenshot.....sorry its missn the thermometer in the shot....but it was at 19c at for the entire time
so this is an H60 with 2 Zalman sharkfin fans mounted in the horizontal position in a silverstone raven2.....
anyone else see or have similar experience with this cooler???
bTx
ps....if you wanna see the rest of my rig its in the project logs under "Bulldozer Blues"
sorry....i didn't win the silicon lottery my friend.....4.8 makes it throug burnintest and unigine but not 3dmarkXX or prime95
when i switched to intel i made myself a promise not to go past 1.4..........i believe my 4.8 was @ 1.384625 give er take a lil......
and my more constant clock of 4.6 runs @ 1.35 but the asus epu helps out alot.....
Temperatures are looking really good for a 4.5GHz OC. Seems like the H60 isn't so bad either. How are those fans performing? I remember they're also using the fluid dynamic bearing for silence as well. They should be quiet even at full speed.
yeah.....they're stupid quiet......i was using a cppl coolermaster excaliburs........HOLY LOUD........i really like the zalmans,,, ive used 'em in a cppl builds now and have only had one crap out on me.......there cfm isnt anything to chirp about but hey...they're silent
That's cool. Zalman hasn't really been making any specific fan. Their fans have always been a bit generalised. But, it's great to see that the Shark is actually performing.
