WMP11 and dlink dsm 510
tinytomlogan
The Guvnor
Staff member
Bought a dsm 510 to stream content from my rig to the new telly but it has to use WMP to sinc and see files.
Now the bugbare, when I tell wmp where all my files are it removes all the vids from there boxes and just lists the files.
Is there a way that wmp 11 can show the folders they are in too like it is on my hard drive, otherwise its massive work reneming everything because my folders are laid out like this,
e:/tv/topgear/series10/e01
All wmp shows is the e01, and I have hundreds of series episodes, and I have no idea what they are till they open!
Im hoping this is a simple fix!??
Hows about this:
How can I view the path and file names for files in my library?
The File Name column displays by default in your library and lists the file names for audio or video files. However, to display both the path and file name for files in your library, you need to display the File Path column.
To display the path and file names for music and videos in your library
1.
In Windows Media Player, click Library.
2.
On the View menu, click Choose Columns.
3.
In the Choose Columns dialog box, select the File Path check box.
4.
If you want, click File Path, and then click the Move Up or Move Down buttons to determine the order in which the column will display in the Details pane of your library.
5.
Click OK.
The path and file names of the different music and video files in your library will now display. To view the File Path column, you may need to scroll to the right in the details pane of your library.
It doesnt work, the DSM 510 still doesnt see the root folders so its all one list, guess its gunna have to go back :(
Now what mini itx case did I like again.......?
