COMPLETED 09/01/2020
Components
CASE: NZXT Manta White Edition
MOTHEROARD: Asrock ITX X570 TB3
CPU: AMD Ryzen 3950x
RAM: Corsair 64gb 3600 CL18 RGB (2x32gb)
GPU: EVGA XC Hybrid 2080 ti
PSU: Corsair AX760i
Watercooling
FITTINGS: Various Bitspower all white
CPU BLOCK: CPU EK-Velocity RGB - Nickel / Acetal
GPU BLOCK: EK-Vector RTX 2080 Ti RGB - Nickel / Acetal
GPU BACKPLATE: EK-Vector RTX - Nickel
PUMP/RES: EK-XRES 100 DDC 3.2 PWM Elite
RADIATOR FRONT: EK-CoolStream XE 240
RADIATOR TOP: EK-CoolStream PE 240
TUBING: Bitspower Crystal Link 10/12mm & Alphacool Hard Tube 10/12mm
Fans
EK-Vardar EVO 120ER White (500-2200rpm)
or
Corsair ML PRO RGB
Accessories
EK-UNI Pump Bracket 120mm - To fit pump res combo to front rad horizontaly
Chamfer Tool - link
Tubing cutting tool - link
Heat gun 2200w - link
Pipe Cutter 3-28mm - link
Goal
My goal is to do my first hard tubing watercool build in a mini itx case with a black a white theme
Still Needed - Questions
I still need to choose what kind of coolant to use, was thinking about a milky white
pastel colour, any ideas what I should choose taking into account the fact that I don't want to be having to change the coolant every two months?
I only have stock PSU cables for my AX760i which are black and dont look to bad, should I invest in custom braided cables, black or white ?
On the accessories list above could somebody with experience check the cutter, chamfer tool & heat gun to see if they will do the job correctly, if not then reccomend me something else?
Notes
Big thanks to Warchild for selling me the fittings, EK Fans & the top radiator (plus some other freebies)
All my orders should be coming in over the next few days so normally I should be building next weekend.
Not sure if I should customise the front of the case with a black sticker any ides or should I leave it as is ?
Updates
1 - Just picked a Cablemod PRO modmesh kit from local ads site brand new for 70 euros, they go far 99 euros on the Cablemod store.
TO BE CONTINUED
Components
PSU: Corsair AX760i
Watercooling
Fans
or
Corsair ML PRO RGB
Accessories
Chamfer Tool - link
Goal
Notes
Updates
TO BE CONTINUED
