White/Blue nzxt switch 810 build attempt
So It's finished for now. I was going to try and sleeve some more stuff but I ran out of MDPC and I think it looks okay for my first time
I spent a couple hours messing around with the wiring trying to make it look cleaner but I was having trouble with the big clumbsy front usb 3 connector and the H100 to cpu fan header cable.
Here you can see the silly H100 cable running across the mobo
quick 3dmark 11 run
i7-3930k @ 4.698
gskill ares 64g @ 1949
EVGA GTX 680 FTW 4gb @ 1262 core, 6220 memory
Not fond of the case, it makes the components look so tiny. But a great job on everything else.
yeah I noticed that too after looking at the pictures. I'm going to get a second card but I think I'm also going to go ahead and water cool it with as beefy of radiators as I can. That should help. I was going to wait to watercool until my next build but after I started this computer building crap i can't stop myself >.< Almost wish I would have discovered a cheaper hobby.
aye PC modding is an expensive hobby, the good thing is every year there are new components so you get to spend your money all over again!
