Hi All,
I am building a new PC, requiring for it to be reliable having a job as a Web/Software Developer as well as enjoying gaming, I am doing a massive upgrade from a stock Asus PC (Nvidia GT 705, 8GB RAM, i5-4460 with some random "286 w" PSU) to my very own custom built PC, to match my monitor scheme which is White and Blue.
I would really appreciate if some of the community members here at OC3D would be able to look over my build and offer their support to my questions as well as their constructive criticism... I really appreciate it!
My List:
- Intel Core i5 7600
- Corsair Vengeance LED 16GB (2x8GB) DDR4
- Corsair Air Series SP120 Blue LED Fan x 4
- MSI GeForce GTX 1060 Armor OC 6GB
- ASRock B250M-Pro4 Motherboard
- Seagate FireCuda 2TB Desktop SSHD
- Phanteks Eclipse P400 S Tempered Glass Glacier White
- Be Quiet! Pure Power 10 500W CM Power Supply
Budget Status: Just about maxed out with these specs, however willing to invest in a better PSU so I don't ruin the rest of the build (See question 1)
Overall, I have a few questions I would like answered, and yes I know many people have biased opinions about some of these questions and I overall just want to hear constructive feedback.
1. Will my PSU be sufficient for my build? And... Is Be Quiet! A recommended brand? I don't want any Power issues to ruin all the components of my build... Parts are expensive
2. I am not too sure about the SSHD's, are they any good, do I invest a lot in a smaller capacity SSD or stick with an SSHD? A friend of mine said they are great for desktops when on a budget and know you don't have to defrag them like you do on a Hard Drive
3. What is the recommended place to put an anti-static wrist strap when building?
4. I was looking at the Cablemod series and was confused what cables I would need to buy to put all of my components together for the build, what is the recommended cables for attaching my PSU to the Motherboard etc?
5. Any extra veteran tips you may add ^_^
I appreciate the replies I will hopefully get from this thread!
Kindest Regards ~ CreedJr
My List:
