Which liquid cooling set to get?
plunderisley
I got a DFI LP NF4 SLI Mobo, FX55, 4GB OCZ ram, 2x 7800 GT, 2x Raptors, 3x SATA, 3x DVD burners in my Thermaltake Armor case. Current temps idle is CPU: 42C, Chipset: 50C, system: 45C, GPU1: 53C, GPU2: 48C. When I load up a game like TF2, GPU jumps up a lot (since I am running 1920x1200) and so does the CPU. I got air cooling in there now, but its noisy and not doing the best job.
I was looking into going into (or back into) liquid cooling. Thing is, I'm in Poland so ordering anything off of any USA based sites is not a current option (until summer when I head back there) and I do plan this summer or upcoming winter time to buy parts for a new PC including 8GB RAM, AMD Phenom, 2 new GPUs with SLI, etc so I would want to transfer the liquid cooling over to the new system. (or at least be able to use it for the CPU + mobo and get a separate one for the GPUS)
I was looking into the Zalman Reserator 2 and getting a northbridge block and another one for the 2nd GPU. Good idea?
Site that I found that I can order from are
http://4max.pl/grupa.asp?gg=61
http://www.aab.com.pl/chlodzenie-wodne-c-11.html
http://www.pc-tuning.pl/Chodzenie+wodne_c42.html
Thanks for your help
zalman is lame, build 2 custom loops to handle your hole pc. And why not dabble into a core 2 quad its faster than a phenom.
