megamindstorm101
Hello I am planning on liquid cooling either a 940 or a 2600k (depending if i get the 2600k by winter or not) and I was looking at the water cooling solutions. I still have a lot of time to think but something I noticed is EK has a TON of choices for the all in 1 kits. I would setup the loop myself but I saw it costs nearly 600$ when I buy all the parts seprate so I figured a kit would be the best way. It was between xspc rasa 750 or the EK kits and from what I see EK seems to be slightly better quality (and a couple hundred more but thats fine). I am wondering though for a CPU only cooling loop which kit is the best to buy?
http://www.ekwaterblocks.com/shop/kits-cases/kits.html?limit=30 there are quite a few choices, all I can tell you is I would like a 360mm radiator.
