jamesriley94
Hi!
Posted a while ago about which video card to buy, responses came back in favour of this - kind of
Will be watercooling at a later date so need a reference designed one.
Check finally cleared in my bank so feel a very large urge to buy some parts now
Choices:
http://www.ebuyer.com/341498-powercolor-hd-7950-3gb-dvi-hdmi-dual-mini-displayport-pci-e-graphics-card-ax7950-3gbd5-2dh
http://www.ebuyer.com/352617-his-hd-7950-fan-3gb-gddr5-dvi-hdmi-dual-mini-displayport-pci-e-h795f3g2m
http://www.ebuyer.com/342090-msi-hd-7950-oc-edition-3gb-dvi-hdmi-dual-mini-displayport-pci-e-r7950-2pmd3gd5-oc-
The MSI one looks favourable to me, and it isnt exactly more expensive. I know I shouldnt pay more for the overclock, but it does have afterburner and voltage tweaks, so I may be able to get more out of it than other cards(?)
What do you guys reckon?
Will be watercooling in around a month, would you recommend any other card though?
I'd prefer to avoid anything with a short PCB because I dont think it will look the best when it's watercooled - ie 670.
Used for gaming - 1080p on one screen, no plans to upgrade to more, but I like the sound of an Overkill rig. Dont think you need anymore info?
Cheers
Choices:
Cheers
