Which 27" Display ?
Dicehunter
Resident Newb
So I'm looking to get a new monitor as i was borrowing my brothers 27" IPS which was awesome but now i need one of my own.
I've been looking at the Asus VS278Q 1MS Gaming Widescreen LED Monitor -
Specification:-
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- True Resolution: 1920x1080
- Full HD 1080P: Yes
- Pixel Pitch: 0.311mm
- Brightness(Max): 300 cd/?
- ASUS Smart Contrast Ratio (ASCR): 80000000:1
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 1ms (Gray to Gray)
- Display Colors: 16.7M
- Stereo Speakers: 2W x 2 Stereo RMS
- Signal Input: HDMI x 2, D-Sub, DisplayPort
- PC Audio Input: 3.5mm Mini-Jack
- AV Audio Input: HDMI
- Earphone jack: 3.5mm Mini-Jack
- Tilt: +20°~-5°
- VESA Wall Mounting: 100x100mm
OR this one -
27" AOC I2757FH LED IPS Pro Full HD Monitor
Specification:-
- Brightness(Max): 250 cd/m²
- Contrast Ratio/DCR: 20000000:1
- Viewing Angle: 178/178 (°H/°V)
- Response Time: 5ms (Gray to Gray)
- Display Colors: 16M
- Stereo Speakers: 4W x 2 Stereo RMS
- Signal Input: 1 x D-Sub, 2 x HDMI
- AV Audio Input: RGB D-Sub
Leaning more towards the AOC IPS, Thoughts ?
P.S Theres also a FM version of this monitor but apart from it being about £16 more expensive and white instead of black/grey i cannot tell the difference, hidden feature maybe ?
For me, both of the monitors you have chosen are big no no's. They are 27" and the resolution is only 1920 x 1080. If you want to get a 27" monitor make sure it is 2560 x 1440 and uses an IPS panel.
However, most IPS panel monitors at 2560 x 1440 are upwards of £400. But they are, in my opinion well worth it. How much are you looking to spend on said monitor?
Below £300
Cool man, it's up to you. What res monitor does you brother have? If it was 1080p and you still liked how it looked, then grab a 27" 1080p IPS monitor.
I have the AOC and love it. I wanted a fast low input lag IPS panel and after seeing the review on TFT Central i couldnt be happier
My lil brothers monitor was 1080p and 27" and i loved it so i think i may just go with the AOC 27" as its an awesome price for an IPS and it looks the mutts nuts ^^
I have to say when I first saw AOC monitors in person, they looked very cheap and I took an instant dislike to them. The actual screen however may be of better quality but I couldn't get past the exterior XD I think it was because the AOC monitors were next to a series of Dell ultra-precision monitors which just look amazing.
Old thread I know but hey ^^
Ended up getting the Asus MX279H, Awesome Monitor, 27" 1080P, AH-IPS.
Might sound crazy but I'm actually not too fond of the 2500 res monitors, makes my eyes go funny ^^
Anyway here it is :) -
