Which 240's to replace a 360?
nepas
I am wanting to change the bottom section of my case around and I currently have a Thermochill p.a.120.3(old type NOT the 15mm spacing) and its just a fraction too bloody long,so I was thinking of using a pair of 240's(one stood on the other)
XXX=current rad
XX
XX =what I want to do
So which would be the best and cheapest way to do it?
How thick and long (end tanks) rads can your system handel ?
Edit; not forgetting hoses ...
tbh,I am only around 30mm short of the space I need by using the 360(case is a Tagan Black Pearl),as it stands with the 360 in there is not enough room to fit the 120mm fan at the front for some HDD cooling.
I'm guessing you want two 60mm thick ones because there would be no point in getting two 30mm thick ones as a 60mm thick one is the same
The cheapest ones would probably be the 240 Phobya G.Changer, keep your eye on Ebay though, there are usually rads going cheap on there.
Or there is always the 80mm thick Monsta rad
http://specialtech.co.uk/spshop/customer/Alphacool-NexXxoS-Monsta-240mm-Dual-Radiator--Full-Copper-pid-15965.html
