May be getting slightly ahead of myself but I've been thinking more about aesthetics and cool mods I could do.  Probably off in the future next time I have some spare cash but still, just ideas.
Firstly, that white LED fan that comes with the case in the front has to go; no idea what they were thinking (other than maybe 'we make a range of fans so lets put one of everything in there' or maybe 'well, we don't make a yellow LED fan so I guess we'll just stick the most neutral LED fan we have in there because LED fans are a selling point'.  Yeah, I think I know exactly what they were thinking, actually).
The problem is that as far as I can tell, nobody makes yellow LED fan, much less 230mm ones.  I dunno if you can make your own LED fan assemblies, I guess it must be possible, but for now I'm thinking Bitfenix Spectre Pro is black for that and the side panel (I could put in more, smaller fans but I just like the idea of huge fans; look cool, work well, run quiet).  Depending on noise and performance, I may replace the ceiling fan with one as well.
http://www.specialtech.co.uk/spshop...-Case-Fan--BFF-SPRO-23030KK-RP-pid-14840.html
Next thing; there's no reset button on the case and the power button has a white LED, which again, doesn't go so well with the rest of the case.  So, I was thinking it'd be possible to remove the fan controller knobs and replace them with Phobya pushbuttons for power and reset.  I've no real interest in fan controllers if the fans I'm running are quiet; rather just hook them up to the PSU and let them do their thing.  I'm also fairly experienced in this kind of mod, after building a bunch of arcade sticks for Xbox (or dual-modded for PS3 and of course, PC too) and don't see it being any kind of issue to do this other than, maybe, the hole left behind from the control knobs being bigger than the 22mm diameter of the thread of the pushbutton but I can get bigger light-up pushbuttons from arcade machine retailers. As for the original power button?  Replace the while LED with a yellow one and leave it as a light-up badge, or I could wire it to be a clear CMOS button or something like that if I really wanted.
http://www.scan.co.uk/products/phobya-71139-push-button-19mm-black-alu-yellow-lighting
I'm not having any optical bays, not water-cooling so I have no real need for the optical drive bays.  It'd also be a little silly doing all this modding and then only viewing it through the mesh in the side panel, so enter clear drive bay covers from KXNG.  Not much description here, just think it'd be worth doing.
http://www.kustompcs.co.uk/acatalog/info_1167.html
Also thinking it would be worth individually braiding my cables.  The multi-coloured cabling from the Silverpower PSU is clearly visible through their braid and it does throw the whole aesthetic somewhat.  Never done this before but since my PSU is mostly modular, I'm comfortable with wires and, if seriously time consuming, this doesn't look particularly difficult to do, I think it's something I'd like to have a go at.  Also, I LOVE the look of individually braided cables.
http://www.kustompcs.co.uk/acatalog/info_24730.html
http://www.kustompcs.co.uk/acatalog/info_7331.html
Finally, some lighting.  Thinking one bar down behind the drive bays, next to the motherboard facing it, since it'll be all clear acrylic there.  Add in a few LED arrays above the vents on the side and I think we'd have one pretty awesome looking rig.
http://www.kustompcs.co.uk/acatalog/info_2251.html
http://www.kustompcs.co.uk/acatalog/info_3323.html
Now my only problem is that the NH-D14 completely doesn't fit the look.  But it performs SO well... ugh.  I've been looking at plain black alternatives but nothing has really caught my eye.  Obviously, the Akasa Venom Voodoo cooler fits the looks perfectly but I'm really hesitant about taking that much of a performance hit (especially in terms of acoustics) for the sake of looks.  Also, Noctua have said that painting the fans could easily result in serious performance implications (as will replacing them, obviously).  Any suggestions?  Been looking at the Thermaltake Frio and Cooler Master V8.  Both seem reasonable but still can get kinda loud; not really sure what way to go with this.
