stevebarnes15
Hi all,i just tried my first overclock in about 7 years but failed misserably.
I've read on other forums that the phenom 2 X6 1055t is capable of speeds up to 4ghz,rather than the stock 2.8ghz.
I used the bios on my gigabyte UD2H,putting auto settings on and just increasing the core clock with a muliplier of 14 but could only get a stable overclock at 3.1ghz.
Anything over that,the system just hangs or crashes during post.
I'm using the stock cooler which keeps the cores at 33 degrees idle,with a little fluctuation between cores,which is 2 degrees max.
When on load running f@h the temps go up to 38 degrees tops.
So is it the memory i'm running preventing a higher oc,which is mushkin enhanced silverline, ddr3 1333mhz,or something else i'm missing?
These are the idle temps:
