I am looking to upgrade my PC but don't know what would be most worth while to upgrade. There is nothing in my build that jumps out at me as being
awful but I think that my case and motherboard are sub par, I know that I defiantly want to upgrade my case because I want a window and my current case doesn't have one, if I got a case with a window then I would need a new motherboard as mine is blue and the colour scheme I had in mind is black and white so it would look out of place. If I was to upgrade my mobo then I am not sure whether to upgrade my CPU at the same time in order to save me having to buy a new mobo if I ever wanted to upgrade my CPU in the future.
PC specs:
Case: Bitfenix Neos
Motherboard: M5A97 LE R2.0
CPU: FX 8350
CPU cooler: raijintek Themis Direct Contact CPU Cooler
RAM: Hyperx Genesis 16GB (2x8GB) 2400Mhz HX24C11BRK2/16-OC
GPU: Gigabyte GTX 1060 6GB (https://www.newegg.com/Product/Product.aspx?Item=N82E16814125901)
PSU: Super Flower 550W
Case fans: 2x Corsair SP120 PWM High Performance, 1x 120mm fan (the one that came with the case)
So what should I upgrade to make my PC look good and get better performance?
Also I would like to do water cooling in the future which is another reason why I want to upgrade my case. Another thing is sometimes when I start a program my headphones stop working, as if they had been unplugged and then immediately plugged back in again, sometimes this happens 5 times times in a row before resolving itself, sometimes the mic just stop working until I close whatever program I opened and sometimes it doesn't happen at all.
One last thing, I currently have a 1080p 60Hz monitor so in order to make use of any performance upgrades I would have to get a better monitor.
Any help would be greatly appreciated, that is if you had the patience to read through all this, thank you in advance for any advice.
PC specs:
Case: Bitfenix Neos
CPU: FX 8350
