G Geomon New member Nov 21, 2005 #1 Just to confirm beforw I buy. I need a 114mm hole cutting saw for a thermochill HE120mm rad yes? Gonna be cutting a Lian Li pc65. Reason I ask is that I see some shops selling 122mm saws but the blowhole cutting guide in the section states that a 114mm saw is needed. Thx
S satman New member Nov 21, 2005 #2 Try this for size. http://cgi.ebay.co.uk/114mm-4-1-1-2...itemZ7550828455QQcategoryZ20785QQcmdZViewItem you will an arbor but he sells them in his ebay shop. If you require a differant size he seems to do them all.
G Geomon New member Dec 8, 2005 #3 satman said: Geomon Have you used the holesaw yet ?. How did it go, i will be cutting 3 120mm blowholes in a new Lian Li PC71 case in christmas holidays. Click to expand... Yes the hole size you need is 114mm, I bought the hole saw and arbor and it cut the holes perfectly altough one of the holes it was a bit tricky as the bit of wood I was using to hold the saw in place held down so the saw wasn't steady. If you want to use the saw then pm me.
