What is a very nice case i can get for under £100?
Coolermaster Storm Trooper
im biased though
well, it really depends on what you want to put in it.
I mean if i had £100 to spend on a case now id buy the bitfenix prodigy simply
because i want to build a small form factor gaming rig and the thing looks
freaking AWESOME
So, tell us what sort of build your doing them we can be more specific
e.g ATX, mATX, ITX, watercooling etc
I think the 500r is a nice case but is $30 over your budget so here are some cases within your budget
MSI Ravager, a bit flashy has a sort of like or hate it design on newegg it is 99.99 normally its 150.
NZXT phantom 410, normally wouldn't say get this case but there are a bunch of new ones out with different paints but they are a bit dated.
Corsair 300r Small and simple from Corsair can't really go wrong.
Corsair 500R in either black or white can be had in the Uk for about £90 or the Fractal Design Define R3 can be had for about £70/£80.
A better explanation of the equipment going in it would help.
Maybe wait for "the case that shall not be named" (CM Stryker) to be released for you to make a decision
for all round purposes I'd say a Corsair 400R. but then again, we don't know your needs or purposes so my answer may be different if you were more specific.
