Dawelio
Active member
Hey guys,
So before any of you ask, I don't have an budget here, but to set a limit, an Titan Z is a bit too much really. And SLI or Xfire isn't really my cup of tea.
I'm planning on going for an ASUS ROG Swift 27" 1440p monitor and looking for a graphics card that cope games at that resolution with High settings, as I don't see a point for Ultra, in games such as Battlefield.
Surround gaming or tripple monitor/eyefinity, is not something for me. I'll just get the Swift and have that for games. Maybe have 1 or 2 more monitors just for side ones, ie have for programs such as Teamspeak etc.
I do have an GTX 980 that I will try and return as recently discovered that within a year, this card won't be enough and 4GB isn't enough. And have recently gotten the advice to sort of "future proof", I'd recommend to go all out and get an Titan X.
I do like the look of the Titan X, only downside is the green LED on it. Since my PC is black and blue.
I've gone with an Sapphire R9 290X Vapor-X earlier, the leds on the back of the PCB did my head in while under different kinds of load, going crazy all of the place.
So my question for you guys are this... which graphics card would you recommend me?
My specs are as follows:
i7 4790K 4.0GHz
ASUS Gryphon Z97 Armor Edition
32GB Corsair Vengeance Pro 1600MHz
Sapphire 6950 2GB
Samsung 840 Pro 256GB
Corsair Force Series 3 180GB
Corsair HX750i
BitFenix Aegis
So yeah... what graphics card would you recommend me etc, based on all of this?.
I know that this might not be the "ultimate" information for you all... but hope you can get me some recommendations though.
Thanks,
Chrazey
i7 4790K 4.0GHz
Sapphire 6950 2GB
Corsair HX750i
BitFenix Aegis
Thanks,
Chrazey
